Legendary
Jun 25, 2017Star
Ping randomly skyrocketing from 20ms to 12,000ms
It all started this morning. I was playing PlayStation 4 with some buddies the all of the sudden I started lagging! So I performed some ping tests and my ping was at about 12,000ms (12 seconds). ...
Michaelsoft
Jun 25, 2017Star
I've been having tons of ping trouble in games lately. I never had a problem until just recently, maybe like 2-3 weeks now. I always had disconnect trouble but never ping issues. I don't know what they did but I feel like they messed something up with recent firmware changes. I'm currently waiting on recieving a link to the beta firmware. I'll let you know if that helps at all.
Legendary
Jun 25, 2017Star
Michaelsoft wrote:I've been having tons of ping trouble in games lately. I never had a problem until just recently, maybe like 2-3 weeks now. I always had disconnect trouble but never ping issues. I don't know what they did but I feel like they messed something up with recent firmware changes. I'm currently waiting on recieving a link to the beta firmware. I'll let you know if that helps at all.
I feel the same way. Firmware update definitely messed something up. I feel like they accidentally sent out a Beta or even an Alpha
- MichaelsoftJun 26, 2017Star
I have been using the beta firmware for several hours and my ping issues are still alive and well. Not sure what the issue is anymore or how to even go about fixing it. Just thought I'd give you an update, good luck.
- peteytestingJun 26, 2017Hero
have you got another router to try as this will remove any doubt weather its the orbi or if its something upstream causing the issue and just being a coincidence
