Legendary
Jun 24, 2017Star
Ping randomly skyrocketing from 20ms to 12,000ms
It all started this morning. I was playing PlayStation 4 with some buddies the all of the sudden I started lagging! So I performed some ping tests and my ping was at about 12,000ms (12 seconds). ...
Michaelsoft
Jun 25, 2017Star
I have been using the beta firmware for several hours and my ping issues are still alive and well. Not sure what the issue is anymore or how to even go about fixing it. Just thought I'd give you an update, good luck.
peteytesting
Jun 25, 2017Hero
have you got another router to try as this will remove any doubt weather its the orbi or if its something upstream causing the issue and just being a coincidence
