Legendary
Jun 24, 2017Star
Ping randomly skyrocketing from 20ms to 12,000ms
It all started this morning. I was playing PlayStation 4 with some buddies the all of the sudden I started lagging! So I performed some ping tests and my ping was at about 12,000ms (12 seconds). ...
Michaelsoft
Jun 25, 2017Star
peteytesting
I did try my old netgear router and overall I'd say the ping issue wasn't prevelant with that router. I noticed some ping fluctuations but they were minor compared to what I'm dealing with when using the Orbi. And this all only started just 2-3 weeks ago. It's odd because all of my speed tests come back great with the Orbi but then I get into an online game and the lag is unbearable.
peteytesting
Jun 25, 2017Hero
have you tried port forwarding or dmz the device you are playing on in the orbi as this may help , certainly a strange one , i would prob even suggest a factory reset and see if that helps
