Legendary
Jun 24, 2017Star
Ping randomly skyrocketing from 20ms to 12,000ms
It all started this morning. I was playing PlayStation 4 with some buddies the all of the sudden I started lagging! So I performed some ping tests and my ping was at about 12,000ms (12 seconds). ...
Michaelsoft
Jun 25, 2017Star
I have done a factory reset but I have not tried port forwarding or dmz. I will look into those options, thanks. And yes it's super strange and nothing netgear support has tried to do has helped and my ISP is claiming everything is good on their end, so I'm at a complete loss. Thanks for the suggestions.
- th3w01fJun 26, 2017Apprentice
I'm seeing similar issues that started probably 3 weeks ago or so. My VoIP perofmrance completly crashed and I've been working with Ooma and my ISP but now I'm thinking the issue might be the Orbi.
Seeing similar to this over and over again.
Reply from 8.8.8.8: bytes=32 time=18ms TTL=60
Reply from 8.8.8.8: bytes=32 time=32ms TTL=60
Reply from 8.8.8.8: bytes=32 time=43ms TTL=60
Reply from 8.8.8.8: bytes=32 time=36ms TTL=60
Reply from 8.8.8.8: bytes=32 time=159ms TTL=60
Reply from 8.8.8.8: bytes=32 time=41ms TTL=60
Reply from 8.8.8.8: bytes=32 time=422ms TTL=60
Reply from 8.8.8.8: bytes=32 time=34ms TTL=60
Reply from 8.8.8.8: bytes=32 time=311ms TTL=60
Reply from 8.8.8.8: bytes=32 time=21ms TTL=60
Reply from 8.8.8.8: bytes=32 time=46ms TTL=60
Reply from 8.8.8.8: bytes=32 time=51ms TTL=60
