Layla38
Mar 03, 2021Tutor
Ping spikes Orbi Satellite RBS50
In my household there are two of these RBS50v2 extenders. When connected via an ethernet cord to one of the boxes, there are no issues. When connected to the other box there are frequent ping spikes. This makes playing games unbearable. Not sure what information you need. Please help me in simple terms.
Turning the box off and on sometimes fixes the ping spikes for a time period.
Layla38 wrote:In my household there are two of these RBS50v2 extenders. When connected via an ethernet cord to one of the boxes, there are no issues. When connected to the other box there are frequent ping spikes. This makes playing games unbearable. Not sure what information you need. Please help me in simple terms.
Turning the box off and on sometimes fixes the ping spikes for a time period.How are the satellites connected?
Do they both connect directly to the router, or does one satellite connect 'through' another satellite?
This will show up on the Orbi web interface Attached Devices page (at the top).
Have you measured these ping spikes?
- Layla38Tutor
It seems the working satellite connects to the router and the one with issues connects through the working one. Internet - > router - > good box - > my box
I have measured the spikes:Reply from 8.8.8.8: bytes=32 time=498ms TTL=113
Reply from 8.8.8.8: bytes=32 time=34ms TTL=113
Reply from 8.8.8.8: bytes=32 time=491ms TTL=113
How are you connexcted to the system? At the RBR or RBS?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What wireless device are you using to test with?
Are you pinging the RBS IP address?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Try using PingPlotter.com with a wired PC connected to the ISP Modem first, then with the RBR inline.
