Layla38
Mar 03, 2021Tutor
Ping spikes Orbi Satellite RBS50
In my household there are two of these RBS50v2 extenders. When connected via an ethernet cord to one of the boxes, there are no issues. When connected to the other box there are frequent ping spikes....
Mar 08, 2021Guru - Experienced User
Turn OFF the RBS and wirelessly connect to the RBR and test pings there first.
Then turn on just 1 RBS, wirelessly or wire connect to the RBS and test pings there.
Layla38
Mar 08, 2021Tutor
Alright I will. Since there can be long breaks between spikes, I will leave these tests running for a time and scan through results. I will let you know what I find in a day or so.
Thanks for you help!
