ransomeb94
Jan 05, 2020Aspirant
Ping/Lag spikes with RBR40
For the last couple of months, we have purchases and been using the Orbi RBR40 with 2 RBW30 Satellites. The router works great except for myself. I play games and stream on a platform called Twitch...
ransomeb94
I have a custom gaming pc with on board wifi. My computer is wirelessly connected. We have the orbi router with 2 satellites and nothing is plugged into the ethernet ports on the orbi router. My pc is connected orbi/satellite.
CrimpOn
Jan 05, 2020Guru - Experienced User
Is the internet modem/wifi/router still operating as a router? is its WiFi on or off?
The Orbi is in "router" or "Access Point" (AP) mode?
- ransomeb94Jan 05, 2020Aspirant
It's on Router Mode, we don't have a physical box for the modem. The modem is in a box on the of the house for the internet company use. The weird part is that the internet was fine for me with the router the internet company provided and never had this happen until we got the orbi
- CrimpOnJan 05, 2020Guru - Experienced User
OK. I think I get it now. (Sorry I am so slow.) The modem is outside in a box and there is an ethernet jack inside the house that their WiFi router was connected to. That was removed and the Orbi plugged in its place, correct?
Just asking: although the WiFi coverage from their router did not cover the entire house, did it provide good coverage to where the gaming PC is located? One option would be to plug their WiFi router back in, use their WiFi for gaming and the Orbi for other things.
Another option is to plug their router back in, turn off the WiFi, and put the Orbi into "Access Point" (AP) mode. This is on the Advanced Tab, Advanced Settings, Router/AP Mode. The theory supporting such a move would be that the Orbi "router functions" are what is creating the extra latency on Ping, and that maybe the Access Point mode will not. There has to be at least one router, and it is better to have only one.
Another avenue to explore is whether the latency issue is "inside the router" or if it is in the "backhaul link" between the router and satellite. The backhaul link is in the 5G spectrum. Some users have reported that their network sound systems set up their own 5G link that may interfere with the Orbi. (Sonos in particular.) Do you have a network sound system?
Can you run a ping test on any other devices, such as something connected to the same satellite or to the router?
