tlat
Mar 31, 2020Aspirant
Pink ring that never goes away
I have restarted, rebooted and re-everything I can and still cannot get rid of the pink ring. When I try to do a firmware update, it says that it cannot. It won't connect to the internet and I have ...
- Apr 15, 2020
If your ISP modem already has a built in router, it should be bridged if possible. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
tlat wrote:Thank you all for the help! I tried the suggestions and still the ring. I cannot get to my admin login on page to even try some of the manual's suggetions. The password I created at the beginning isn't working and it won't let me enter "password" for the start up. does anyone know how to basically treat this Orbi like it's brand new and reset everything? When I look up why the ring is happening, it says that it's not recognizing my xfinity router, but we have wifi (not through the orbi) so I know it's working. I tried a different ethernet cable thinking that might be the issue and i'm not sure how to tell what firmware is on the orbi or how to even update it since I cannot access the admin area. I'm not really tech savy, but aside from my teenagers, I'm the only one in the house capable of trying to fix the issue. thanks again!
Mar 31, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
tlat wrote:I have restarted, rebooted and re-everything I can and still cannot get rid of the pink ring. When I try to do a firmware update, it says that it cannot. It won't connect to the internet and I have tried a different ethernet cable to see if that was it.
I tried to call customer support but due to the virus, there isn't anyone answering. If anyone can help I would truly appreciate it. With 5 people social distancing at home doing work, school and gaming, we need the orbi.
Thanks!
- Retired_MemberApr 01, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
What ask about the firmware when you never address the problems with some releases?
- tlatApr 15, 2020Aspirant
- Retired_MemberApr 15, 2020
