Retired_Member's avatar
Retired_Member
Mar 05, 2017
Piper NV Security cameras
Hi, guys.
I can't connect the security cameras after installing the Orbi router and the satellites.
It looks like the network doesn't see them.
Any help will be appreciated.
Cheers,
Gino.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello GinoTorres
    Is there any requirements for these cameras? Do they need any type of port forwarding?
    DarrenM
    • Retired_Member's avatar
      Retired_Member
      Hi, Darren
      Did a hard reset on the cameras. Now working well.
      Thanks!!
