tivotron
Jan 31, 2022Aspirant
Playstation 4 not blocked
Long time reader, first time poster. Thank you in advance. Trying to pause internet connection to son's PS4. I see the device in the Orbi device list, MAC address matches what I see on the device...
Feb 01, 2022Guru - Experienced User
Are you using Orbi app to select the PS console?
Do you have a IP address Reservation set up for this device ON the router?
Is access controls enabled on the RBR?
- tivotronFeb 03, 2022Aspirant
First of all --- thank you! Really love when a community comes together to help.
Answers to your questions (and more questions):
FURRYe38 wrote:Are you using Orbi app to select the PS console?
Yes, Orbi app on my phone. I am able to successfully turn off the Internet to other wired & wireless devices on my home network.
I do not.
Where would I check this? I am able to block other devices.
- FURRYe38Feb 03, 2022Guru - Experienced User
So the PS4 is the only one not being blocked when you disable internet for it while all other devices seem to be blocked for them correct?
I do not. Something to try. Under Advanced Tab/Setup/LAN Setup.
Under Advanced Tab/Advanced/Security/Access Controls or Advanced Tab/Security/Access Controls I believe.
Comments below. Thank you so much again!!!
FURRYe38 wrote:
tivotron wrote:Are you using Orbi app to select the PS console?
Yes, that is correct. All other devices seem to be blockable.
Looks like there is an IP address reserved for the PS4 listed in this table.
Checked this. Access controls are enabled.
