Cruz101
Feb 27, 2021Follower
PlayStation won’t stay connected to Orbi RBR10
I got my Orbi router back in December, it works like a charm in till about 2 weeks after getting in, my PS4 will connect to in they out of nowhere disconnects. I have contacted PlayStation they told m...
Feb 28, 2021Guru - Experienced User
What modem/gateway is the RBR10 connected to?
Is your playstation connected to the router or satellite?
Is the playstation hardwired into the router/satellite or running over wireless?
if its over wireless is it over the 2.4ghz or 5ghz?
When it disconnects, what actual error are you getting? Is it fully disconnecting from the wireless/wired or is it saying "connected, no internet"?
What fixes the issue?
How frequently is it happening?
