jasondunn
Nov 29, 2017Apprentice
Please allow unique SSIDs for Both Bands
I understand the logic that Netgear wants to make everything simple, and having just a single network to connect to is indeed simpler than having two. However, there are some downsides to this. This...
- Nov 29, 2017
You can actually by following the instructions listed in this posting, I just did that and it works:
https://community.netgear.com/t5/Orbi/How-to-set-a-separate-SSID-for-the-5-GHz-network-on-your-Orbi/m-p/1396594
jasondunn
Nov 30, 2017Apprentice
Retired_Member wrote:In the case of other devices that can use both 2.4 and 5g, how does the Orbi decide which freq to assign? Is it based on current network load conditions, etc.?...I too have another device that requires a setup through a Iphone app and will only run on the 2.4ghz band. When I went to set it up, my Iphone 6plus was already connected to the 2.4 ghz band and things went fine. I'm just wondering why your phone went to 5g? Is it because the Orbi decided that was best for the moment and will it change later?
Yes to all of that. WiFi devices will connect automatically to the strongest signal, and there's a sort of handshake that goes on between the device and the Orbi when it first connects (and each time it comes back into range). Part of that handshake is going to be "what WiFi frequencies can you support?" along with "which frequency are you getting the strongest" and if 5Ghz is an option, that's what network the device will be put on. I am not aware of any setting in Android or iOS that allows you to control which WiFi band to use - all you can control is what SSID you connect to.
In your case, your iPhone was getting a weak 5Ghz signal and was assigned to the 2.4 Ghz spectrum. If you go near your router, turn off WiFi, then turn it back on, I'm certain it would lock onto the 5Ghz signal.
Your post did give me an idea though I'm going to try later: I'll turn off WiFi, walk outside my house, turn it back on and hopefully get my phone onto the 2.4Ghz network and then try the setup again.
I saw the other post about using Telnet to change the SSIDs - that's a brilliant tip that I may use, but it will be a last resort - I really appreciate it being shared!
Retired_Member
Dec 19, 2017
Hey Jason....did you ever get a fix for this? My one weather station that needs a iphone hooked up to 2.4g is giving me a problem. Last night I had to power down one of my sats due to the constant blue light. Now my iphone only connects to 5g. then the weather station lost its wifi connection..not sure if its related. trying to reconnect i need the phone on 2.4g but the orbi puts it on 5g.
- jasondunnDec 19, 2017Apprentice
Hey Jason....did you ever get a fix for this? My one weather station that needs a iphone hooked up to 2.4g is giving me a problem. Last night I had to power down one of my sats due to the constant blue light. Now my iphone only connects to 5g. then the weather station lost its wifi connection..not sure if its related. trying to reconnect i need the phone on 2.4g but the orbi puts it on 5g.Yes, I was able to get this working. I had to use the telnet solution outlined here:
NetGear is seemingly ignorant of devices like this that only can get set up on the 2.4Ghz band.
- Retired_MemberDec 19, 2017
Thanks
I'll think I'll hold off on any mechanical (telnet) adjustments. Too many horror stories from the past. Something else I'd like to try is setup a guest 2.4g network on the Orbi. Then login my iphone in there and see if the weather station will connect. I tried it last night and it didn't work but that might have been I was in a hurry and feeling frustrated. The Lacrossse app for the weather station is a bit quirky. Think I'll try it again tonight.
Retired_Member wrote:I'll think I'll hold off on any mechanical (telnet) adjustments. Too many horror stories from the past. Something else I'd like to try is setup a guest 2.4g network on the Orbi. Then login my iphone in there and see if the weather station will connect. I tried it last night and it didn't work but that might have been I was in a hurry and feeling frustrated.
That might work if you're willing to leave the weather station permanently connected to the guest network - and leave the guest network on forever. Otherwise it will never be associated with your main network, and never be on the same subnet and accessible by your iPhone.
