12345_12
Aug 26, 2019Aspirant
Please Help - Orbi RBR50 - assigning frequencies - splitting freqencies
Can you help ? I have a Orbi RBR50 with 3 satellites. All are wired. I am using a BT modem but have switched off the wireless so only the Orbi is broadcasting. I cannot connect to older devices. I ...
12345_12
Aug 27, 2019Aspirant
Many thanks to both responses. I tried both and some units connected but i still cant get the Sonos to connect. I will try Sonos directly. Thankyou
Aug 27, 2019Guru - Experienced User
Can try this as a quick temporary test, disable WPA on the Orbi. See if the SONOs connects. If it does, then try WPA and TPIK and see if it connects. Last mode would be WPA2 and AES only...
