Brads515
Jun 28, 2018Guide
Please Help! Can not login to Orbi Satellite anymore!
Hi all... Need some help and have no idea what is happening here... I can no longer login to my Orbit Satellite, but I can login to the router....my default password no longer works and I have rese...
Jun 28, 2018Guru - Experienced User
Whats the Mfr and model# of the ISP modem? Built in router here by chance?
How are you connected to the Orbi router? Recommend wired LAN cable to the back of the router. Besure your not connected to any other router.
What IP address is your PC getting from the router?
What broswer are you using?
Brads515
Jun 28, 2018Guide
Thanks! My modem is an Arris TM804 -- not connected to anything else (another router, etc) -- the Orbi is the only router I have in my house.
The IP Address I am getting for the satellite is 192.168.1.14 -- using Google Chrome but tried Edge as well and same thing - can not log into the Satellite anymore!
