iabd
Sep 10, 2019Aspirant
Please Help-No access-websites not loading (404 messages)-Orbi RBR20-Mac OS and iOS
Hi Community—I've been encountering a lot of error messages and hoping someone can help. I run Mac OS 10.14.5 (Mohave) and iOS 12.4 on iPhone Xr. Orbi is connected via CAT 6 to an (wifi disabled)...
Sep 10, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
iabd wrote:Hi Community—I've been encountering a lot of error messages and hoping someone can help.
I run Mac OS 10.14.5 (Mohave) and iOS 12.4 on iPhone Xr. Orbi is connected via CAT 6 to an (wifi disabled) Arris modem supplied by Spectrum. I get 404 messages repeatedly, but not consistently. Orbi app denies access, says login incorrect. Have reset password 2X. No avail. Try downloading firmware updates, get 404 message. No access to orbilogin.com. I'm blocked at every turn.
iabd
Here's another error message, trying to access support through Netgear.
