sansfil
Apr 22, 2017Aspirant
Please help Orbi interferes with Bluetooth Headphones/Speaker
Hi everyone, I have not found an answer on the forum so far and therefore I hope this post helps me and others experiencing interference issues. Since I updated from my Netgear R7800 with an EX7300 e...
sansfil
Thanks st_shaw, I was not aware that Zigbee also uses WiFi channels. What still bothers me is that everything used to work without interference before (with the R7800 and extender) and unfortunately some devices need the 2.4 Ghz frequency and can not be upgraded. Any further ideas are more than welcome.
peteytesting
Apr 22, 2017Hero
just try changing channels on the 2.4 gig , try ether ch 1 , 6 or 11 and see if that helps
- sansfilApr 25, 2017Aspirant
Like I said in the original post, already tried changing channels to 1,6,11 and 12. Is it somehow possible to disable the wide mode in 2.4 Ghz? Disabling 20/40 coexistence makes it 40 unfortunately.
