ZeusyZeus
Jun 11, 2020Aspirant
Please help! Samsung HW-Q90R Soundbar WIFI issues
Hello everyone, I'm desperately in need of some help I'm having the weirdest issue. I have searched everywhere online and I can't seem to find any help on it. My Orbi router RBR50 has been working fl...
Jun 12, 2020Guru - Experienced User
If you have a pad, then download NG WiFi Analitics app, or WiFi analyzer is the one I like, also Ubiquity WiFiman is a good app.
ZeusyZeus
Jun 12, 2020Aspirant
NG WiFi analytics I don’t see in Apple App Store, and the one you like I believe is $3.99. The WiFi man one doesn’t show any information on channels. I’m trying to find out what channels my neighbors are on to see which are congested the most.
- FURRYe38Jun 12, 2020Guru - Experienced User
WiFiman shows channels. You have to select one of the SSID Names from the list then that will bring up more info about each SSID you see. You can also look for Net Analyzer for pad as well.
- fade6Jun 18, 2020Aspirant
FYI - please see my latest post. This will resolve the issue. To my knowledge, ALL wireless speakers (subwoofers, rears) rely on the same 5 GHz channel range that is used by Orbi's backhaul.
- ZeusyZeusJun 18, 2020AspirantThanks a lot fade6! Unfortunately I tried those steps and it didn’t work for me. I’m going to give it another shot. I responded to your post.
