eternaleigh
Mar 31, 2020Aspirant
PLEASE HELP with RBR20 maximizing upload speeds
I currently have an orbi mesh system with router (RBR20 - firmware V2.3.5.30) with 2 satellites (RBS20 - firmware V2.3.5.30). My internet speeds are sh*thouse to say the least but its the best i can ...
eternaleigh
Apr 03, 2020Aspirant
Thanks for your reply. Sorry, life got in the way. About to troubleshoot it now though and try your suggestions. I wanted to send you responses to your questions too. Here ya go:
ISP modem is Arris NVG443B
Home is 1600 square feet, router is 25 feet from 1st satellite and 2nd satellite is 30 ft max from the 1st one.
Channels: Auto on 2.4Ghz and 40 on 5Ghz
2 wifi neighbors.
Gonna try everything you suggested and see what happens. Ill keep you posted and make notes as i move through each scenario.
Thanks again!
Apr 03, 2020Guru - Experienced User
Be aware that you ISP modem has a built in router.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure to start RBS distance at 30 feet. Any closer could cuase problems...
Good Luck.
- eternaleighApr 03, 2020Aspirant
I already have ISP router in bridge mode. Orbi is in router mode. And I have all WiFi radios on ISP router disabled.
Current settings im trying:
2.4Ghz channel 11
MIMO, WMM and beamforming enabled
Disabled: Armor, circle, daisy chain, fast roaming, IPv6 (was already disabled) and turned off 20/40Mhz coexistence (couldnt find setting to force 40Mhz only)
With these settings, my upload speed went down a little. Not a lot, but didnt increase.
- FURRYe38Apr 03, 2020Guru - Experienced User
Try for a while. Might try a different channel or set back to auto.
ISP router says its in bridge mode but still shows ISP protocol as PPPoE. Should i change that to transparent bridging? and should i diasble DCHP no ISP router as well?
