Ozymandias_EBON
Oct 09, 2022Tutor
Please, Please, Please add "Force Ethernet Backhaul" to settings!!
I love my Orbi system (Router + 2 Sats) but the inability to force ethernet backhaul is such a pain. If the power flickers, all devices reboot and will try to reconnect. Since the router takes a bi...
- Nov 10, 2022
I did another emulated power cycle. ARP storm happened again with the RBS connected via ethernet with LAN switch, seems to go about 1 minute or a bit longer this time however stopped and the system continued working fine.
I thought maybe having the web page opened on the RBRs web page was contributing to this but no, happens with the browser closed. Seems that a power outage then back on will trigger the storm however only seems to last for about a minute then stops.
Ozymandias_EBON
Nov 08, 2022Tutor
I found a workaround that minimizes the network loops created by the satellites.
To reiterate, the real solution would be a setting where you can select backhaul priority.
1) Wireless Only (Default)
2) Ethernet Only
3) Ethernet First / Wireless Second
Netgear should change the method the satellites connect as the current method causes network loops.
Back to the workaround...
1) All devices powered off.
2) Power on satellites
3) Wait until ALL satellites show ethernet activity (it takes about 30-45 seconds for each)
4) Power on Router (main unit).
I had another power flicker yesterday.
Using this process I was back up completely in about 5 minutes with no loops.
And for good measure, I did pick up some UPS's for the satellites.
Nov 08, 2022Guru - Experienced User
Ethernet backhaul works as intended. Only factors that can cause problems are bad or incorrect CAT# cableing, bad cabling plugs or jacks or bad patch panels, use of managed switches that haven't had there IGMP protocols and green ethernet features disabled. Seen some non managed off branded switches cause problems as well. Not all switches are the same.
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems. XS505M and GS110MX work great with the 9 series.
There would be no reason for force ethernet backhaul. And besides NG keeps the system set for automatic configuration so if something does happen on the ethernet connection, the RBS can fall back to wireless backhaul.
