NabsG's avatar
NabsG
Plex, Orbi, sky router and shield
I have Plex sitting on a server behind orbi which is connected (wired) to a sky router. Orbi is unstable in AP mode and therefore is in a double nat situation.
I cannot put the sky into a bridge mode. How do I get around this?
Please walk me though and I am not very good with networks.
By the way the sky router sits on 192.168.0.1, and the orbi on 192.168.1.1.
  • FURRYe38's avatar
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
    If you still want to use the Orbi in router mode, then try option #2. For easy use of Orbi with your ISP router, i would use option #3.
    Please walk me though and I am not very good with networks. whatsapp
    Same thing happen with me.
    • FURRYe38's avatar
      Did you resolve your problem?
  • FURRYe38's avatar
    Any progress on this?
