fuzzevans
Jan 07, 2021Aspirant
Plex Remote Access
To start, my system is listed as an AC2200 (RBK23), but that wasn't an option, so I've selected something as close as I could. I am attempting to setup Plex Remote Access in my network, but runni...
- Jan 07, 2021
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
fuzzevans
I believe this indicates it's 'routed' - but if I'm misunderstanding this configuration, let me know.
Jan 07, 2021Guru - Experienced User
Couple of options,
