Misses
Jan 24, 2020Follower
Plug in satellite
I recently purchased an Orbi AC3000 and would like to know which plug in satelite would work with it. The only one I find says it works with AC2200. Please advise.. Thank You :)
Jan 24, 2020Guru - Experienced User
with that version anyway. Not quite the same if you had the AX Orbi.
Jan 25, 2020Guru - Experienced User
Orbi AC satellites are not compaible with Orbi AX currently. NG is supposed to make them compatible. I believe some of them and not all. No time frame on when this will happen.
