alokeprasad
Oct 28, 2023Mentor
Plugging devices to the ethernet ports of RBS53 knocks it off the network
After manually updating the firmware's on my one RBR and 2 RBS's, everything works fine, with good wireless backhaul between the router and the satellites. When I connect 2 devices (Dish hopper an...
alokeprasad
Oct 28, 2023Mentor
I confirmed this with the second satellite.
It drops connection with the RBR sporadically until I disconnected a couple of Ethernet cables from the satellite (and switched those devices to WiFi). After that, the satellite-router connection is rock solid.
Very weird.
alokeprasad
Oct 30, 2023Mentor
Any idea why the satellites don't like the use of its Ethernet ports?
Could they be getting confused by expecting a wired backhaul if I connect a device o the ports? I am spitballing here.
Any settings that I should check to allow the use of the Ethernet ports without disturbing the wireless connection between the RBR and tge RBS's?
