englemt
Nov 07, 2016Aspirant
point to point distance
I am considering buying this for my father. He has a garage that is about 120 feet away from his house. I can put both Orbi's in a window and they will have line of sight. Do you have any guidance...
netwrks
Nov 07, 2016Master
Glass is not your friend, (deflector) in wireless environments. And, the distance may also be an issue. If you decide to try, make sure you that you can get a full refund, if it does not work out.. If at all possible, consider an outdoor Access Point, with a proper outdoor Ethernet cable buried..
