RobFisher
Jun 10, 2019Aspirant
Poor Backha
I have an Orbi RBR50 system with two satellites. I have an Ethernet cable making the long haul to the Orbi in the TV room. I have a Kodi system which play movies and series from my PC and it worked b...
- Jun 10, 2019
I had the same problem with my concrete-and-steel split level.
The problem was solved for me by turning the 2.4GHz radio strength down to 25%. I was told in the beginning, that Orbi wants to use WiFi backhaul at almost ANY cost. So, while we are prevented from turning off the 2.4GHz radio, we can weaken it to the point it can't be used efficiently... Forcing the use of 5GHz and Ethernet.
My working concept is: Since it works, I don't care to understand anything more than that.
At least it's a quick and easily-reversible thing to try.
Steedvlx600
Jun 10, 2019Luminary
RobFisher
Thank you! I will try that... just need to work out how to do that... off to play now!
- Steedvlx600Jun 10, 2019Luminary
It's in advanced settings --> WiFi
- RobFisherJun 10, 2019Aspirant
Thanks! Found it it! Now to test! Thank you!
- RobFisherJun 11, 2019Aspirant
OH WOW! Thank you so much! That WORKED! It still shows the backahul as poor but the problem has gone and we can watch without any interupptions! I am very grateful! You gotta love the community!
Thank you again... you saved my sanity!
