Mjanssen
May 23, 2020Guide
Poor backhaul status after Config Sync
Hi, I'm having difficulties with getting a stable backhaul connection using the RBR40 and 1 RBW30 satelite. The backhaul status almost all the time shows as "Poor", whatever I try for the loc...
- May 28, 2020
Hi,
Seems like changing the pre-amble fixed the issue. The backhaul status is GOOD on 5G and the overal wifi experience is a lot better!
Didn't even try the factory reset yet.
Thanks for the tip!
Mjanssen
May 23, 2020Guide
** UPDATE **
Manually updated the firmware to V2.5.1.16 for the RBR40 and V2.5.0.2 for the RBW30.
No change, behaviour is exactly the same :smileysad:
