Mjanssen
May 23, 2020Guide
Poor backhaul status after Config Sync
Hi, I'm having difficulties with getting a stable backhaul connection using the RBR40 and 1 RBW30 satelite. The backhaul status almost all the time shows as "Poor", whatever I try for the loc...
- May 28, 2020
Hi,
Seems like changing the pre-amble fixed the issue. The backhaul status is GOOD on 5G and the overal wifi experience is a lot better!
Didn't even try the factory reset yet.
Thanks for the tip!
Mjanssen
May 23, 2020Guide
** UPDATE **
Manually updated the firmware to V2.5.1.16 for the RBR40 and V2.5.0.2 for the RBW30.
No change, behaviour is exactly the same :smileysad:
May 23, 2020Guru - Experienced User
- MjanssenMay 23, 2020Guide
Hi FURRYe38,
Thanks for your response. Saw some of your other posts with some of the same suggestions you mention here. :smileywink:
The house does have walls between the RBR and the RBW, but not much.
We also unplugged the RBW for a while and most devices were able to connect to the RBR, some with less bars and speed, but still connected.
At first used 2.4G channel on auto, tried 1, 6 and 11. No change.
There are some wifi neighbors, not exactly sure how many (not at the location right now :smileywink: ), but I was able to find a free 2.4G channel before. Also for 5G.
Armor and Circle are disabled?
Can't set the Set 20/40Mhz Coexistence to 40Mhz only, only disable it completely.
Changed the preamble to short just now, will monitor if any change.
Will do a factory reset when at the location in the near future. Is there a way to save settings? Or is restoring settings not recommended.
Can you explain why the backhaul is good for a short while after any of the wifi settings?
- FURRYe38May 23, 2020Guru - Experienced User
What is the distance between the RBR and RBW?
When you uncheck the 20/40Mhz box this sets 40Mhz only.
Under Advanced Tab/Advanced Settings/Administration is Backup. You can maybe a back up configuration to file. I would first factory reset the system and setup from scratch and not load any saved config files. Need to first test the system from a clean setup condition first.
Possible there is a RBW problem. Seen others with this modem RBW have problems. I feel the FW on the RBW needs to be updated by NG to be more in line with v16 which is most correct for the Orbi AC line of systems.
Tried every distance from 5m and 20m between the RBR and the RBW. Left it at each distance for a couple of hours and monitored the backhaul status.
Will try the factory default option somewhere in the next weeks
The devices are not new. Can it still be updated by NG to get a more stable connection?
