Mjanssen's avatar
May 23, 2020
Poor backhaul status after Config Sync
Hi,   I'm having difficulties with getting a stable backhaul connection using the RBR40 and 1 RBW30 satelite.   The backhaul status almost all the time shows as "Poor", whatever I try for the loc...
  • Mjanssen's avatar
    Mjanssen
    May 28, 2020
    Hi,
    Seems like changing the pre-amble fixed the issue. The backhaul status is GOOD on 5G and the overal wifi experience is a lot better!
    Didn't even try the factory reset yet.
    Thanks for the tip!
