Mjanssen
May 23, 2020Guide
Poor backhaul status after Config Sync
Hi, I'm having difficulties with getting a stable backhaul connection using the RBR40 and 1 RBW30 satelite. The backhaul status almost all the time shows as "Poor", whatever I try for the loc...
- May 28, 2020
Hi,
Seems like changing the pre-amble fixed the issue. The backhaul status is GOOD on 5G and the overal wifi experience is a lot better!
Didn't even try the factory reset yet.
Thanks for the tip!
May 23, 2020Guru - Experienced User
Something to contact NG support and report your experiences.
Mjanssen
May 28, 2020Guide
Hi,
Thanks for the tip!
- FURRYe38May 28, 2020Guru - Experienced User
Glad you got it working.
Enjoy. :smileywink:
