5aboy
Jan 05, 2020Aspirant
Poor link speed
5aboy
I have rbr40 and rbs20w
The link speed is atrocious.
I'll get 700mbps right next to the router but in the next room (standard construction UK house ) it drops to 30mbps. This is whilst my virgin router gives me 250mvps in the same place.
Iv tried lots of settings with no improvement.
What to do.?
What to do.?
michaelkenward
Jan 06, 2020Guru - Experienced User
Are you using these things side by side?
If so, is the Orbi in wireless access point mode?
5aboy wrote:
I'll get 700mbps right next to the router ....
What is this device that gives you those speeds? 700Mbps is faster than most wifi clients can deliver.
- 5aboyJan 07, 2020AspirantHi.
Re the 700mbps..I'm talking just about link speed...if the link speed drops to 30 then even with 100pc quality you wont get 200mbps download per the wan connection..I'm aware of that.
The orbi router is in ap mode.
This issue is that the devices are connecting at low speed and not high
