StanDenman
May 30, 2023Aspirant
Poor net speed
I cannot figure out what model I have from the drop down. In the orbi app I see model number "RBR10". Firmware Version v2.7.4.24. I have had poor VOIP call quality via RingCentral. The speed on m...
May 30, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try putting the VoIP device into the RBRs DMZ.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
- StanDenmanMay 31, 2023Aspirant
Sorry you are going to have to speak English. What is a DMZ?
- StanDenmanJun 09, 2023Aspirant
None of this has worked.
None of these suggestions helped. Speed worse than ever!!
- KevinLiTJun 09, 2023NETGEAR Moderator
Hello StanDenman ,
Thank you for providing that information!
Please do a speed test from your RBR10 then post your findings.
To do a speed test from your RBR10 please navigate to the following settings:
Orbilogin.com> Advanced> Setup> Speed Test
Best,
Kevin
Community Team
