StanDenman
May 30, 2023Aspirant
Poor net speed
I cannot figure out what model I have from the drop down. In the orbi app I see model number "RBR10". Firmware Version v2.7.4.24. I have had poor VOIP call quality via RingCentral. The speed on m...
schumaku
Jun 10, 2023Guru - Experienced User
StanDenman wrote:
Yet on the orbi app I do a "Speedtest" and I get 53 download, 12 upload.
This is a speed test run direct on the Orbi router direct, testing the wired network and Internet connection.
StanDenman wrote:
The speed on my PC - where I do all my work - on the orbi network is quite slow. 17 download, 12 upload.
On my laptop in that same office, on the orbi network I get 30 download, 12 upload.
Both wireless connections of course, not making use of the available Gigabit Ethernet LAN port of course, isn't it?
Is the Orbi router free visible from the position where the PC and the laptop are used?
What wireless clients are installed on the PC and the laptop?
Windows or MacOS systems?
When open the computer wireless properties (of the connected network name) on a Windows system, there is an option to copy the current status, it's a list like this (hope you don't worry about the German localization in use here) - this is what I would like to see from the PC as well as from your laptop - this is what could help of giving us an idea about the wireless connection status of each device (PC, laptop):
SSID: xxxxxx
Protokoll: Wi-Fi 6 (802.11ax)
Sicherheitstyp: WPA2-Personal
Netzfrequenzbereich: 5 GHz
Netzwerkkanal: 40
Verbindungsgeschwindigkeit (Empfang/Übertragung): 961/907 (Mbps)
Hersteller: Intel Corporation
Beschreibung: Intel(R) Wi-Fi 6 AX200 160MHz
Treiberversion: 22.220.0.4
Physische Adresse (MAC): xx-xx-xx-xx-xx-xx
This is about the last issue - once the wireless connection can be considered good to very-good, we can look into this.
StanDenman
Jun 10, 2023Aspirant
This is the desktop (the one that is the slowest)This one is the laptop which is faster (network band 2.4 GHz)
- schumakuJun 10, 2023Guru - Experienced User
Laptop:
Realtek 8811CU, a single chip 802.11ac 1x1, Wave-2 compatible with MU-MIMO, the host interface is USB2.0 for WLAN and BT controller. Typically available in the market as a USB Wi-Fi 5 dongle, apparently synching on 5 GHz to 130 Mbps / 130 Mbps
Is this USB WiFi stick probably connected on a USB 1.0/1.1 port? Probably connected on some aged USB hub? These are typical reason for very poor performing WiFi (while showing reasonable link rates).
Worth to update the driver so some current (late) version, like https://www.realtek.com/en/component/zoo/category/rtl8811cu-software (32bit/64bit Windows7, Windows8.1, Windows10 WLAN USB driver (Install Package) 1030.25.0701.2017 2018/09/07) - [edit: seems to be in place already?]
If correctly deployed, not delivering, but should perform within these limits.
Notebook:
Realtek RTL8723DE, a dated 802.11n Wi-Fi 4 adapter, a single chip solution, combining PCIe and a USB backed Bluetooth host, synching on the Wi-Fi 2.4 GHz band (that's all it can) to 72 Mbps / 72 Mbps.
- StanDenmanJun 10, 2023Aspirant
Sorry I do not understand your reply. The desktop has a tripp-lite doggle - no other identification. I bought this PC refurbished from PCLiquidations last year. Are you saying I need to replace the wifi adaptor?
- schumakuJun 11, 2023Guru - Experienced User
Fire up the Windows device manager for some peek-and-poke on the USB controllers (where I still suspect the Wi-Fi adapter is connected, and the Network Adapter properties.
