TottenhamNJ
Sep 18, 2020Aspirant
Poor Network Quality
Ive got the Orbi RBR 20. Set it up last weekend and haven't had any issues. Today, I had issues with poor network quality. Even got a message from Microsoft Teams that my network was causing poor call...
Sep 18, 2020Guru - Experienced User
TottenhamNJ
Seriosuly?
Firmware V2.5.1.16
Dont know the router manufacturer, it doesnt say
Size of the house isnt the issue I am in the room directly above where the Oribi router is.
No idea what channels Im using or how to change them
Im in a neighborhood, so yeah a bunch of other wifi around
No clue what "beamforming" is or anythign else you've asked
- FURRYe38Sep 18, 2020Guru - Experienced User
You might want to get a friend, nieghbor or family member to help you out with this...
- TottenhamNJSep 18, 2020Aspirant
I can guanatee you that i know not one singe indiviudal who knows what any of this iis
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).It needs to be a setting in the app or part of the admin settings. If thats the case great but say that. Setting this up and getting it to work properly shouldnt require IT support.
These are part of the RBRs web page admin settings that can be found at 192.168.1.1 or orbilogin.net.
Just to check these settings.
The other questions are important as aswell, if you can give feed back.
Please review the user manual for additional information.
