gx3
Jun 28, 2022Aspirant
poor performance of RBK23 satellites
Just upgraded our internet plan from 250 Mbps to 500 Mbps. Devices connected to the router are getting good speeds. Devices connected to the RBS (2) have had no improvement in speed. Approx 130-140 ...
Jun 29, 2022Guru - Experienced User
Try hardwiring a pc/laptop into the satellite. Then speedtest the device.
that lets you check the wireless backhaul connection without the fronthaul being a bottleneck.
If you're still getting the same speed, try moving the satellite around and testing speeds in different locations. It might have something blocking the connection back to the router or causing interference.
gx3
Jun 29, 2022Aspirant
I'll give that a try. Thank you.
