CordThomas
Dec 29, 2018Tutor
Poor range between router and satellite - RBR50
I have an older house, circa 1950 with plaster walls. I have the RBR50 near the middle of our house. I am trying to setup the RSR50 satellite on the far side of one wall about 25 feet from the rout...
- Dec 29, 2018
CordThomas wrote:
The status of the satellite is Good.
What tool would you recommend for a WiFi scan? I have Mac and iPhone. On the iPhone I have installed a few WiFi tools but none seem to give me a neighborhood scan.
My Mac's WiFi lists only about 6 other networks it can see. I live in a residential neighborhood without too many people living that close by.
Since you have a Mac you can use the native wifi analyser in MacOS as follows:
- Press Option key + Click on the Wi-Fi menu item in OS X
- Choose “Open Wireless Diagnostics”
- Go to the “Window” menu and choose “Scan” to immediately open the Wi-Fi Stumbler tool built into Mac OS X
- Within the Scanner tool, click on the Scan button to scan for available networks
- This will open the wireless card to detect all possible nearby wifi networks, effectively stumbling onto available wireless routers and discovering details about those networks.
Dec 29, 2018Guru - Experienced User
When you disabled Daisy Chain, is the check mark removed from the box or check in the box?
CordThomas wrote:
Turning off daisy chain made a dramatic improvement to throughput. With enabled, i was getting ~40 Mbps on devices connected to the satellite. With disabled, I am getting 500-600 Mbps...
CordThomas
Dec 29, 2018Tutor
The checkbox is unchecked which I believe to be disabled. Since it is enabled by default (what i read online at least), it was checked to begin with and I unchecked it. I did see someone mention that with the latest firmware it might be reversed but that's not what it appears to be for me.
