CordThomas
Dec 29, 2018Tutor
Poor range between router and satellite - RBR50
I have an older house, circa 1950 with plaster walls. I have the RBR50 near the middle of our house. I am trying to setup the RSR50 satellite on the far side of one wall about 25 feet from the rout...
- Dec 29, 2018
CordThomas wrote:
The status of the satellite is Good.
What tool would you recommend for a WiFi scan? I have Mac and iPhone. On the iPhone I have installed a few WiFi tools but none seem to give me a neighborhood scan.
My Mac's WiFi lists only about 6 other networks it can see. I live in a residential neighborhood without too many people living that close by.
Since you have a Mac you can use the native wifi analyser in MacOS as follows:
- Press Option key + Click on the Wi-Fi menu item in OS X
- Choose “Open Wireless Diagnostics”
- Go to the “Window” menu and choose “Scan” to immediately open the Wi-Fi Stumbler tool built into Mac OS X
- Within the Scanner tool, click on the Scan button to scan for available networks
- This will open the wireless card to detect all possible nearby wifi networks, effectively stumbling onto available wireless routers and discovering details about those networks.
ekhalil
Dec 29, 2018Master
CordThomas
Dec 29, 2018Tutor
Thank you for the tip - works like a charm. I've had this Mac (a recovering Windows person) for over 5 years and did not know that existed.
It doesn't look like anyone else is on our channels - 2.4 GHz is 4 and 5 GHz is 48 - all clear it would appear.
- ekhalilDec 29, 2018Master
Great. Then it's good to choose one of the non-overlapping 2.4 GHz channels: 1, 6 or 11 as fixed 2.4 GHz channel.
Good luck
