mastervisa30
Nov 02, 2018Luminary
Poor signal on one satelite after uppdate to V2.2.1.210
Hello got my new orbi yesterday working great.
When i wake upp today its been uppdating to V2.2.1.210
now i have poor signal on the closest satelite.
I been using orbi before one the same place...
Nov 02, 2018Guru - Experienced User
Try a power cycle OFF then back ON with the Orbi system?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
