Kuikenj
Jul 30, 2019Aspirant
Poor stability, frequent disconnects
Hello, I purchased an Orbi RBK53 with two sattelites from Costco. I moved into my new place, installed my cable ISP (spectrum) and have had frequent disconnects and interupptions in my Wifi capa...
Jul 30, 2019Guru - Experienced User
You might want to upgrade the system to v30 as that is the most current version of FW. Update the RBS first, then the RBR lastly. Factory reset the RBS and RBR and setup from scratch. Walk thru the setup wizard with a wired PC and web browser.
- KuikenjJul 30, 2019Aspirant
Ok, I’ll attempt to change the channel and update the firmware etc. Currently having difficulty logging into the router. I’ve cleared the cache and its saying router isn’t connected to the network, when clearly it is or I wouldn’t be able to respond. :-)
- FURRYe38Jul 30, 2019Guru - Experienced User
Try a different wired PC. Try using 192.168.1.1 as well...
I have updated the firm ware to V30.
I have changed the manual channel to 6 on 2.4 ghz
i have enabled beamforming and mimo
Unclear If it worked or not.
How are the RBS placed in relation to the RBR? Out in a line or in a star configuration?
Daisy Chain is for RBS that are placed out in a line from the RBR and having two or more RBS. Might have to play with this some.
Whats the status of the RBS say? Good?
The RBS are in a star configuration, with the RBR in the middle on the first floor, RBS 2 in the basement for the XBOX and RBS 1 in the 2nd floor for the corporate laptop, and the iPads and iPhones that are in use.
It’s gone down twice in the last 2 hours. What else should I try?
thank you for all your help
