Kuikenj
Jul 30, 2019Aspirant
Poor stability, frequent disconnects
Hello, I purchased an Orbi RBK53 with two sattelites from Costco. I moved into my new place, installed my cable ISP (spectrum) and have had frequent disconnects and interupptions in my Wifi capa...
Jul 30, 2019Guru - Experienced User
You might want to upgrade the system to v30 as that is the most current version of FW. Update the RBS first, then the RBR lastly. Factory reset the RBS and RBR and setup from scratch. Walk thru the setup wizard with a wired PC and web browser.
Kuikenj
Ok, I’ll attempt to change the channel and update the firmware etc. Currently having difficulty logging into the router. I’ve cleared the cache and its saying router isn’t connected to the network, when clearly it is or I wouldn’t be able to respond. :-)
- FURRYe38Jul 30, 2019Guru - Experienced User
Try a different wired PC. Try using 192.168.1.1 as well...
