Kuikenj
Jul 30, 2019Aspirant
Poor stability, frequent disconnects
Hello, I purchased an Orbi RBK53 with two sattelites from Costco. I moved into my new place, installed my cable ISP (spectrum) and have had frequent disconnects and interupptions in my Wifi capa...
Kuikenj
Ok, I’ll attempt to change the channel and update the firmware etc. Currently having difficulty logging into the router. I’ve cleared the cache and its saying router isn’t connected to the network, when clearly it is or I wouldn’t be able to respond. :-)
Jul 30, 2019Guru - Experienced User
Try a different wired PC. Try using 192.168.1.1 as well...
