Kuikenj
Jul 30, 2019Aspirant
Poor stability, frequent disconnects
Hello, I purchased an Orbi RBK53 with two sattelites from Costco. I moved into my new place, installed my cable ISP (spectrum) and have had frequent disconnects and interupptions in my Wifi capa...
Kuikenj
I have updated the firm ware to V30.
I have changed the manual channel to 6 on 2.4 ghz
i have enabled beamforming and mimo
Unclear If it worked or not.
Jul 30, 2019Guru - Experienced User
How are the RBS placed in relation to the RBR? Out in a line or in a star configuration?
Daisy Chain is for RBS that are placed out in a line from the RBR and having two or more RBS. Might have to play with this some.
Whats the status of the RBS say? Good?
- KuikenjJul 30, 2019Aspirant
The RBS are in a star configuration, with the RBR in the middle on the first floor, RBS 2 in the basement for the XBOX and RBS 1 in the 2nd floor for the corporate laptop, and the iPads and iPhones that are in use.
It’s gone down twice in the last 2 hours. What else should I try?
thank you for all your help
- FURRYe38Jul 30, 2019Guru - Experienced User
Lets remove the RBS from the system for a bit. Just turn them off. See if the RBR is stable by itself...
Kuikenj wrote:The RBS are in a star configuration, with the RBR in the middle on the first floor, RBS 2 in the basement for the XBOX and RBS 1 in the 2nd floor for the corporate laptop, and the iPads and iPhones that are in use.
Just tried that experiment. Turned the satellites off, sat down to watch some Netflix with my son using the router only. Lasted not even 10 minutes before the router went down again
now what?
