Kuikenj
Jul 30, 2019Aspirant
Poor stability, frequent disconnects
Hello, I purchased an Orbi RBK53 with two sattelites from Costco. I moved into my new place, installed my cable ISP (spectrum) and have had frequent disconnects and interupptions in my Wifi capa...
Retired_Member
Jul 30, 2019
Kuikenj wrote:Hello,
I purchased an Orbi RBK53 with two sattelites from Costco. I moved into my new place, installed my cable ISP (spectrum) and have had frequent disconnects and interupptions in my Wifi capability from the Orbi. It disconnects about 1-2x per hour!
I work from home, and I'm not a tech expert, but the cable isn't having an issue while the Orbi disconnects. I expect to be able to take this thing out of the box, plug it in and have it work. I fired the unit up on 7/26, so it should have the latest firm ware.
If this can't be fixed quickly, its going to go back to Costco and I will find a router that is stable! Help!
what was your old router?
