welverin's avatar
welverin
poor wifi performance of Orbi RBK20 (max 12MB/s)
Hi all, I intensively tested the RBK20 orbi and the real performances are lower than expected. The system is set as AP, the master and the satellite are connected via ethernet, the tests were perf...
  • SW_'s avatar
    SW_
    Oct 16, 2019
    welverin wrote:
    but in theory which would be the maximum tranfer rate through an orbi ?
    to understand how i am far from best case
    Just a guess here.  Given RBK20 fronthaul @866Mbps, which is half of RBK53 backhual @1733Mbps, if you can get close to 20MB/s, that would be reasonable.  Based on a similar test I did on RBK53 via its backhaul @1733Mbps, the peak ~40MB/s.  If your wired client could get 30-50MB/s, that's also within the ball park of my test because my wired client could hit ~90MB/s.  Check out this post for more details.
    You can also verify if you hit Orbi peak performance by replacing Orbi with an exisitng WiFi router if you have a spare one lying around or turn on WiFi on your exisitng router if it's a combo.
