tadBR
Dec 14, 2016Guide
poor wireless performance on devices connected to orbi router
I am experiencing very bad wifi performance on devices connected to orbi router with instability and wifi speeds below 100mbps (tested with wi-fi sweetspots) in front of the router. Speed when device...
- Dec 15, 2016
Hello tadBR
You may want to try and factory reset the router to make sure it was not a issue with a setting but if that does persist contact support as they can figure out if that is a defect or not in the unit and replace it if needed.
DarrenM
DarrenM
Dec 15, 2016Sr. NETGEAR Moderator
Hello tadBR
What is your Internet speed and what type of devices are getting the slow speeds?
DarrenM
