tadBR
Dec 14, 2016Guide
poor wireless performance on devices connected to orbi router
I am experiencing very bad wifi performance on devices connected to orbi router with instability and wifi speeds below 100mbps (tested with wi-fi sweetspots) in front of the router. Speed when device...
- Dec 15, 2016
Hello tadBR
You may want to try and factory reset the router to make sure it was not a issue with a setting but if that does persist contact support as they can figure out if that is a defect or not in the unit and replace it if needed.
DarrenM
tadBR
Dec 15, 2016Guide
My internet speed is 120mbps by cable
My devices are mostly apple devices like iphone 7, airpads, a new macbook 12 and a samsung notebook and a synology nas.
When devices are connected to the sattelite, the have 300mbps average speed. When they are conected i have 10-20 mbps average and a very unstable connection. I can't even get 100mbps when connected to the router.
- GaryInEdmondDec 15, 2016Guide
I would call their customer support as this is not the typical experience. I regularly get over Mbps on my desktop computer connected via wifi.
http://www.dslreports.com/speedtest/7377337
In areas that didn't have wifi coverage before the Orbi I get over 100Mbps.
When you call customer support, there is, or at least there was, an option specifically for the Orbi.
- DarrenMDec 15, 2016Sr. NETGEAR Moderator
Hello tadBR
DarrenM
