tadBR
Dec 14, 2016Guide
poor wireless performance on devices connected to orbi router
I am experiencing very bad wifi performance on devices connected to orbi router with instability and wifi speeds below 100mbps (tested with wi-fi sweetspots) in front of the router. Speed when device...
- Dec 15, 2016
Hello tadBR
You may want to try and factory reset the router to make sure it was not a issue with a setting but if that does persist contact support as they can figure out if that is a defect or not in the unit and replace it if needed.
DarrenM
GaryInEdmond
Dec 15, 2016Guide
I would call their customer support as this is not the typical experience. I regularly get over Mbps on my desktop computer connected via wifi.
http://www.dslreports.com/speedtest/7377337
In areas that didn't have wifi coverage before the Orbi I get over 100Mbps.
When you call customer support, there is, or at least there was, an option specifically for the Orbi.
DarrenM
Dec 15, 2016Sr. NETGEAR Moderator
Hello tadBR
DarrenM
