DerAlfmeister
Sep 28, 2016Aspirant
Poor Wireless Throughput
Is anyone else experiencing poor throughput when on wireless. Wired I get the expected 300M, my provided port speed. When on Wireless connected to the "Router" my speed test will start out fast and th...
peteytesting
Sep 28, 2016Hero
you will prob find that 300Mbps internet is poss beyond the limits of the wan to lan although i havnt tested it , works fine here on my 100/40Mbps line
it also depends on if your connecting to the 2.4 gig or 5 gig transmission
check what speed the adapter is connecting at
- DerAlfmeisterSep 29, 2016Aspirant
Interestingly this morning all is well. Connecting to the same channel as yesterday (5GHz/48) I'm able to get the full 300M as I would expect. Even went to a device on the satelite and was able to pull 200M which is great. I don't know what may have changed or what was going on with the network since last night when I was running the test but it's working as expected now. Hopefully they'll add Guest access and then it'll be perfect!
