MAN45's avatar
MAN45
Follower
Aug 31, 2019
Port Forward Orbi and DM200 to HIK Vision CCTV Not Working
Please help.
Recently changed my Plusnet (UK ISP provided) modem/router for a Netgear DM200 modem (modem only mode) and Orbi 50 mesh system. Everthing works well except I cannot get the port forwarding to work. I've been on the phone to Netgear and CCTV people and the Orbi port forwarding has been set up as normal in the advance section, however the ports do not appear open when I talk to the CCTV Tech guys. On my IVMS-4500 app I can see the system whilst on my home network, but not cannot view remotely. Originally tried it with the DM200 on the default modem and router setting but that did not work either. I have reset the systems many times but to no avail, spent 90min on netgear helpline but they weren't great to be honest.
The system worked fine on the free ISP plusnet router and having logged onto the HikVision system the ports havent changed and are the ones I am trying to port forward.
What am I doing wrong please. I am not a technical expert so lost with some of the answers given in forums.
1 Reply
  • FURRYe38's avatar
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    I would try option #2 first, if that doesn't help, configure Orbi for #3...
    MAN45 wrote:
    Please help.
