Stream62
May 27, 2021Aspirant
Port Forwarding - Multiple Internal IP Problems - RBR10 Orbi Router
Hi, I am getting "moderate" NAT when gaming (Call of Duty in this case) and have two computers connected that I play on - a Dell laptop and a gaming PC. I am trying to port forward to two interna...
- May 27, 2021
Do you have NAT Filter feature listed as a menu item under Advanced tab/Setup/Internet or WAN page on the RBR?
Stream62
Hi there,
Yes i do, under Advanced > Setup > WAN Setup.
There is the NAT Filtering section with options of Secured and Open, as well as a tick box for "Disable SIP ALG".
I've changed the option from Secured to Open and after restarting everything i seem to have Open NAT in COD on both computers.
Thanks for the help.
May 27, 2021Guru - Experienced User
You can re-enable uPnP as well.
Please mark your thread and solved so others will know.
Enjoy.
- FURRYe38May 27, 2021Guru - Experienced User
Enjoy. :smileywink:
