PayGoneCray
Jun 12, 2023Aspirant
Port forwarding disconnects the whole internet CBR40
Hey there so I've been wanting to play with my friends and I'm the only one who knows how to port forward and everything so I do that. After a while my dad starts telling me the internet is messi...
Jun 12, 2023Guru - Experienced User
What Firmware version is currently loaded on the CBR and RBS?
FW on these should be from this page here:
https://www.netgear.com/support/product/cbk40#download
FW versions between the CBR and RBS should be near or on same version as what the CBR is using.
What game are you trying to play online.
Normally no Port Forwarding is needed as long as uPnP is enabled.
Be sure your setting up the CBR correctly for any PF Configurations. Disable uPnP if you setup any PF Configurations.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
PayGoneCray
For the CBS it's v2.5.0.28 and RBS is v2.5.1.16 and it said it was up to date from the online which is odd.
As for the games it's mainly Minecraft
- PayGoneCrayJun 12, 2023Aspirant
Actually I just updated the Satellite and it's now V2.7.3.22 but the router still wont update as it's apparently the same firmware
- FURRYe38Jun 12, 2023Guru - Experienced User
Ya that maybe a problem. Normally the RBS needs to use that same version of FW or near same version as what's loaded on the CBR. Any far out of range FW version could cause problems.
CBR is on 2.5x and the RBS is on 2.7x. Not sure how this would all work being kind of out of FW version range.
Might turn OFF the RBS and just test your configurations at the CBR first...
Yes but if you have noticed those are the latest versions I installed so I don't know what's up.
